Command reference
vserver nfs tls interface disable
Disable NFS TLS on a LIF
The vserver nfs tls interface disable command disables NFS TLS on a logical interface.
-vserver <vserver name> - Vserver
This parameter specifies the Vserver in which the logical interface exists.
-lif <lif-name> - Logical Interface
This parameter specifies the name of the logical interface on which you want to disable NFS TLS.
The following example disables NFS TLS on a Vserver named vs0 and a logical interface named datalif1.
vs1::> vserver nfs tls interface disable -vserver vs0 -lif datalif1
