Command reference
vserver nfs tls interface enable
Enable NFS TLS on a LIF
The vserver nfs tls interface enable command enables NFS TLS on a logical interface.
-vserver <vserver name> - Vserver
This parameter specifies the Vserver in which the logical interface exists.
-lif <lif-name> - Logical Interface
This parameter specifies the name of the logical interface on which you want to enable NFS TLS.
[-certificate-name <text>] - TLS Certificate Name
This parameter specifies the name of a certificate to be associated with the instance of a given Vserver and logical interface.
Note The use of self-signed SSL certificates exposes users to man-in-the-middle security attacks. Where possible, obtain a certificate that is signed by a reputable certificate authority (CA) and use the security certificate install command to configure it before enabling TLS on a Vserver and LIF.
[-skip-san-validation {true|false}] - Skip Certificate's Subject Alternate Name Validation
This parameter specifies whether Subject Alternate Name (SAN) validation is skipped. The default value is false .
The following example enables NFS TLS on a Vserver named vs0 and a logical interface named datalif1. The certificate name is lif1.com which is preinstalled on server.
vs1::> vserver nfs tls interface enable -vserver vs0 -lif datalif1 -certificate-name lif1.com
