Command reference
vserver nvme subsystem controller show
Display active NVMe controllers
The vserver nvme subsystem controller show command displays information for established NVMe controllers. An NVMe controller is established upon each host connection to a subsystem.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the NVMe controllers that match the Vserver that you specify.
[-subsystem <text>] - Subsystem
Use this parameter to display the NVMe controllers that match the subsystem that you specify.
[-controller-id <Hex 16bit Integer>] - Controller ID
Use this parameter to display the NVMe controllers that match the controller ID that you specify. The controller ID is the identifier assigned by the NVMe subsystem upon host login and controller creation.
[-lif <text>] - Logical Interface
Use this parameter to display the NVMe controllers that match the LIF that you specify.
[-node <nodename>] - Node
Use this parameter to display the NVMe controllers that match the cluster node that you specify.
[-host-nqn <text>] - Host NQN
Use this parameter to display the NVMe controllers that match the host NQN that you specify. The host NQN is the NVMe identifier assigned to a specific host.
[-transport-protocol {fc-nvme|nvme-tcp}] - Transport Protocol
Use this parameter to display the NVMe controllers that match the transport protocol that you specify.
[-initiator-transport-address <text>] - Initiator Transport Address
Use this parameter to display the NVMe controllers that match the initiator transport address that you specify. The initiator transport address format depends on the transport protocol in use.
[-host-id <Hex String>] - Host Identifier
Use this parameter to display the NVMe controllers that match the host identifier that you specify. The host identifier is a 128-bit identifier assigned to a specific host.
[-io-queue-count <integer>] - Number of I/O Queues
Use this parameter to display the NVMe controllers that match the I/O queue count that you specify.
[-io-queue-depth <integer>,…​] - I/O Queue Depths
Use this parameter to display the NVMe controllers that match the I/O queue depth that you specify.
[-admin-queue-depth <integer>] - Admin Queue Depth
Use this parameter to display the NVMe controllers that match the administrative queue depth that you specify.
[-max-io-size <integer>] - Max I/O Size in Bytes
Use this parameter to display the NVMe controllers that match the maximum I/O size (in bytes) that you specify.
[-kato <integer>] - Keep-Alive Timeout (msec)
Use this parameter to display the NVMe controllers that match the keep-alive timeout value (in msec) that you specify.
[-subsystem-uuid <UUID>] - Subsystem UUID
Use this parameter to display the NVMe controllers that match the Subsystem UUID that you specify.
[-header-digest-enabled {true|false}] - Header Digest Enabled
Use this parameter to display the NVMe controllers that have header digest enabled.
[-data-digest-enabled {true|false}] - Data Digest Enabled
Use this parameter to display the NVMe controllers that have data digest enabled.
[-dhchap-hash-function {sha-256|sha-512}] - Authentication Hash Function
Use this parameter to display the NVMe controllers that connected with the specified hash function using DH-HMAC-CHAP in-band authentication.
[-dhchap-dh-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit}] - Authentication Diffie-Hellman Group
Use this parameter to display the NVMe controllers that connected with the specified Diffie-Hellman group size using DH-HMAC-CHAP in-band authentication.
[-dhchap-mode {none|unidirectional|bidirectional}] - Authentication Mode
Use this parameter to display the NVMe controllers that connected with the specified mode for DH-HMAC-CHAP in-band authentication.
[-trsvcid <text>] - Transport Service Identifier
Use this parameter to display the NVMe controllers that match the transport service identifier that you specify.
[-tls-key-type {none|configured}] - TLS Key Type
Use this parameter to display the NVMe controllers that have the specified NVMe/TLS-TCP encryption key type.
[-tls-psk-identity <text>] - TLS PSK Identity
Use this parameter to display the NVMe controllers that have the specified NVMe/TLS-TCP encryption PSK identity.
[-tls-cipher {TLS-AES-128-GCM-SHA256|TLS-AES-256-GCM-SHA384}] - TLS Cipher
Use this parameter to display the NVMe controllers that use the specified NVMe/TLS-TCP encryption cipher.
cluster1::*> vserver nvme subsystem controller show -vserver vs_1 -subsystem ss1
Vserver Subsystem    ID LIF    Host NQN
vs_1    ss1
                  0003h lif1   nqn.2001-08.example.com:nvme:host1
                  0004h lif1   nqn.2001-08.example.com:nvme:host2
                  0009h lif2   nqn.2001-08.example.com:nvme:host1
                  000Ah lif2   nqn.2001-08.example.com:nvme:host2
4 entries were displayed.
