Command reference
vserver object-store-server bucket evict-remote-cached-objects
Evict remote read-write cached objects
The vserver object-store-server evict-remote-cached-objects command will evict read-write dirty cached objects in all constituent volumes of a given object store server bucket. This command will evict only objects that are cached on a different volume than its origin volume. This command requires two parameters - a Vserver name and an object store server bucket name.
-vserver <Vserver Name> - Vserver Name (privilege: advanced)
This specifies the name of the Vserver for the object store server.
-bucket <TextNoCase> - Object Store Server Bucket Name (privilege: advanced)
This specifies the name of the object store server bucket.
The following example starts the command:
cluster1::>vserver object-store-server bucket evict-remote-cached-objects -vserver my-vserver -bucket my-bkt
