Command reference
vserver vscan on-demand-task delete
Delete an On-Demand task
The vserver vscan on-demand-task delete command deletes an On-Demand task.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver from which you want to delete an On-Demand task.
-task-name <text> - Task Name
This parameter specifies the name of the On-Demand task that you want to delete.
The following example deletes an On-Demand task:
cluster1::> vserver vscan on-demand-task delete -vserver vs1 -task-name t1
cluster1::> vserver vscan on-demand-task show -vserver vs1 -task-name t1
There are no entries matching your query.
