Command reference
vserver vscan scanner-pool delete
Delete a scanner pool
The vserver vscan scanner-pool delete command deletes a scanner pool.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver from which you want to delete a scanner pool.
-scanner-pool <Scanner pool> - Scanner Pool
This parameter specifies the name of the scanner-pool that you want to delete.
The following example deletes a scanner pool.
cluster1::> vserver vscan scanner-pool delete -vserver vs1 -scanner-pool test
cluster1::> vserver vscan scanner-pool show -vserver vs1 -scanner-pool test
There are no entries matching your query.
