debug hwpmc delete
Delete or cancel a HWPMC profile
The debug hwpmc delete command allows the user to delete or cancel Hardware Performance Monitoring Counter profiles.
-node {<nodename>|local}- Node Name (privilege: advanced)-
This parameter specifies the node on which the profile was collected.
-name <text>- Name of the HWPMC Profile (privilege: advanced)-
This parameter specifies the name of the profile that will be deleted.
The following example deletes a profile that was collected on node1:
cluster1::> debug hwpmc delete -node node1 -name 2023_06_06-08_53_44_UTC
