Command reference
metrocluster configuration-settings interface modify
Modify a MetroCluster interface
The metrocluster configuration-settings interface modify command modifies the network logical interfaces that were provisioned for MetroCluster.
-cluster-name <Cluster name> - Cluster Name (privilege: advanced)
Use this parameter to specify the name of the local or partner cluster.
-home-node <text> - Home Node (privilege: advanced)
Use this parameter to specify the home node in the cluster which hosts the interface.
-home-port {<netport>|<ifgrp>} - Home Port (privilege: advanced)
Use this parameter to specify the home port provisioned for MetroCluster.
[-address <IP Address>] - Network Address (privilege: advanced)
Use this parameter to specify the network address to be assigned to the home port.
[-netmask <Contiguous IP Mask>] - Netmask (privilege: advanced)
Use this parameter to specify the network mask to be assigned to the interface.
[-gateway <IP Address>] - Gateway (privilege: advanced)
Use this parameter to specify the gateway address to be assigned to the interface.
