qos settings nested-qos-svm-vol
Enable/Disable SVM Vol level Nested QoS feature
The qos settings nested-qos-svm-vol command is used to enable or disable the nested Qos feature at SVM-Vol level. The default is enabled. With this feature enabled, the user can attach a shared policy group on the parent SVM while the child FlexGroup/FlexVol already has a shared, non shared or adaptive policy group attached to it or vice versa.
-enable {true|false}- enable or disable svm vol level nested QoS feature (privilege: advanced)-
This specifies if nested QoS feature at SVM-Vol level is enabled or disabled. If this parameter is specified with
falsenested QoS at SVM-Vol level will be disabled.
The following example disables nested QoS feature at SVM-Vol level.
cluster1::*> qos settings nested-qos-svm-vol -enable false
