Command reference
security anti-ransomware auto-enable modify
The security anti-ransomware auto-enable modify command changes the cluster-level auto enablement setting for new volumes.
[-new-volume-auto-enable {true|false}] - Auto-enable ARP Setting for New Volumes
Sets the Auto-Enable Anti-Ransomware Protection setting for newly created volumes. Specify true to automatically enable Anti-Ransomware on new volumes.
[-warm-up-period-total-duration <time_interval>] - Warm-up Period Total Duration
Sets the total duration of the warm-up period.
cluster1::> security anti-ransomware auto-enable modify -new-volume-auto-enable false -warm-up-period-total-duration 24h
Disables auto-enablement of Anti-Ransomware protection for new volumes and adjusts warm-up period duration to 24 hours.
cluster1::> security anti-ransomware auto-enable show
New Volume Auto-Enable:          false
Warm-Up Period Applicable:       true
Warm-Up Period Completed:        false
Warm-Up Period Duration:         24h
Warm-Up Period Time Remaining:   10h
After warm-up period ends, warm-up related fields wont be displayed.
