security cluster-network certificate create
Specify the certificate used for cluster security
The security cluster-network certificate create command creates a certificate entry for the cluster security feature configuration on one node.
-node <nodename>- Node Name-
Node name.
-name <text>- Certificate Name-
The certificate name used for the cluster security feature for the specified node.
The following example creates a certificate entry for the cluster security feature configuration on one node.
cluster1::> security cluster-network certificate create -node node1 -name installed_cert_sample
