security cluster-network certificate delete
Remove the certificate used for cluster security
The security cluster-network certificate delete command removes the certificate for the cluster security feature configuration on one node.
-node <nodename>- Node Name-
Node name.
The following example removes the certificate used for cluster security.
cluster1::> security cluster-network certificate delete -node node1 -name installed_cert_sample
