security cluster-network certificate modify
Modify the certificate used for cluster security
The security cluster-network certificate modify command modifies the certificate used for by a specified node for the cluster security feature configuration.
-node <nodename>- Node Name-
Node name.
[-name <text>]- Certificate Name-
The certificate name used by the specified node for the cluster security feature.
The following example modifies the certificate used by a specified node for the cluster security feature configuration.
cluster1::> security cluster-network certificate modify -node node1 -name installed_cert_sample
