Command reference
security cluster-network certificate renew
Renew cluster security certificates
The security cluster-network certificate renew command renews all system generated cluster security certificates.
The following example renews all system generated certificates in the cluster security feature configuration.
cluster1::> security cluster-network certificate renew
