Command reference
security cluster-network certificate show
Show the certificates used for cluster security
The security cluster-network certificate show command displays the certificates used for the cluster security feature configuration.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node <nodename>] - Node Name
Node name.
[-name <text>] - Certificate Name
The certificate name used by the specified node for the cluster security feature.
[-uuid <UUID>] - Certificate UUID
Certificate UUID.
[-ca <text>] - Certificate Authority
The certificate's issuer.
The following example displays the certificate information for the cluster security feature configuration.
cluster1::> security cluster-network certificate show
Node                  Certificate Name           Certificate Authority
node1                 cluster1_1850F6011570F72E  CA_cluster1
node2                 cluster1_11570F72E332222   CA_cluster1
2 entries were displayed.
