Command reference
security ha-network modify
Modify HA network security configuration
The security ha network modify command modifies the HA network security in a cluster.
-enabled {true|false} - HA Network Security Enabled
Whether to enable ha network security.
The following example enables the ha network security configuration.
cluster1:: security ha network modify -enabled true
