security ha-network show
Show HA network security configuration
The security ha-network show command displays the HA network security in a cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name-
Node name.
[-enabled {true|false}]- HA Network Security Enabled-
This parameter shows the status of the HA network security.
