Command reference
security login rest-role show
Show REST access control roles
The security login rest-role show command displays the following information about Representational State Transfer (REST) access-control roles:
  • Vserver
  • Role name
  • Application Programming Interface (API) to which the REST role has access
  • Access Level (none , readonly , read_create , read_modify , read_create_modify , or all )
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
Selects the REST roles that match this parameter value.
[-role <text>] - Role Name
Selects the REST roles that match this parameter value. If this parameter and the -api parameter are both used, the command displays detailed information about the specified REST access-control role.
[-api <text>] - API Path
Selects the REST roles that match this parameter value. If this parameter and the -role parameter are both used, the command displays detailed information about the specified REST access-control role. This API can be a private CLI API or a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
  • Snapshots APIs
  • /api/storage/volumes/{volume.uuid}/snapshots
  • File System Analytics APIs
  • /api/storage/volumes/{volume.uuid}/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/clients
  • /api/storage/volumes/{volume.uuid}/top-metrics/directories
  • /api/storage/volumes/{volume.uuid}/top-metrics/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/users
  • /api/svm/svms/{svm.uuid}/top-metrics/clients
  • /api/svm/svms/{svm.uuid}/top-metrics/directories
  • /api/svm/svms/{svm.uuid}/top-metrics/files
  • /api/svm/svms/{svm.uuid}/top-metrics/users
  • ONTAP S3 APIs
  • /api/protocols/s3/services/{svm.uuid}/users
  • Private-cli APIs
  • /api/private/cli/cluster
In the APIs above, and in the context of REST roles, the wildcard character * can be used in place of {volume.uuid} or {svm.uuid} to represent all volumes or all SVMs, depending on whether the REST endpoint references volumes or SVMs. The {volume.uuid} corresponds to the -instance-uuid field in the output of the volume show command at the diagnostic privilege level. It can also be retrieved through the REST endpoint /api/storage/volumes .
[-access {none|readonly|read_create|read_modify|read_create_modify|all}] - Access Level
Selects the roles that match this parameter value.
The example below displays information about all REST access-control roles:
cluster1::> security login rest-role show
Role                            Access
      Vserver           Name            API             Level
      vs                vsrole1         /api            none
      vs                vsrole1         /api/storage/volumes/f8a541b5-b68c-11ea-9581-005056bbabe6/files
                                                        all
      vs                vsrole1         /api/storage/volumes/f8a541b5-b68c-11ea-9581-005056bbabe6/snapshots
                                                        readonly
      vs                vsrole1         /api/storage/volumes/843b87f9-2f5e-11ec-9524-005056bb0bee/snapshots
                                                        read_create
      vs                vsrole1         /api/svm/svms/843b87f9-2f5e-11ec-9524-005056bb0bee/top-metrics/clients
                                                        read_create
      cluster1          readonly        /api/storage    none
      cluster1          custom          /api/cluster    read_modify
      cluster1          custom          /api/security/accounts
                                                        read_create_modify
      cluster1          custom          /api/storage/volumes/*/top-metrics/users
                                                        readonly
      cluster1          custom          /api/storage/volumes/*/snapshots
                                                        all
      cluster1::>
