Command reference
security ssh add
Add SSH configuration options
The ` security ssh add ` command adds additional SSH key exchange algorithms or ciphers or MAC algorithms to the existing configurations of the cluster or a Vserver. The added algorithms or ciphers or MAC algorithms are enabled on the cluster or Vserver. If you change the cluster configuration settings, it is used as the default for all newly created Vservers. The existing SSH key exchange algorithms, ciphers, and MAC algorithms remain unchanged in the configuration. If the SSH key exchange algorithms or ciphers or MAC algorithms are already enabled in the current configuration, the command will does not not fail. ONTAP supports the diffie-hellman-group-exchange-sha256 , diffie-hellman-group16-sha512 and diffie-hellman-group18-sha512 key exchange algorithms for SHA-2. ONTAP also supports the diffie-hellman-group-exchange-sha1 , diffie-hellman-group14-sha1 , and diffie-hellman-group1-sha1 SSH key exchange algorithms for SHA-1. The SHA-2 key exchange algorithm is more secure than the SHA-1 key exchange algorithms. ONTAP also supports ecdh-sha2-nistp256 , ecdh-sha2-nistp384 , ecdh-sha2-nistp521 , and curve25519-sha256 . ONTAP also supports the AES and 3DES symmetric encryptions (also known as ciphers) of the following types: aes256-ctr , aes192-ctr , aes128-ctr , aes256-cbc , aes192-cbc , aes128-cbc , aes128-gcm , aes256-gcm , and 3des-cbc . ONTAP supports MAC algorithms of the following types: hmac-sha1 , hmac-sha1-96 , hmac-md5 , hmac-md5-96 , umac-64 , umac-64 , umac-128 , hmac-sha2-256 , hmac-sha2-512 , hmac-sha1-etm , hmac-sha1-96-etm , hmac-sha2-256-etm , hmac-sha2-512-etm , hmac-md5-etm , hmac-md5-96-etm , umac-64-etm , and umac-128-etm . ONTAP supports host key algorithms of the following types: ecdsa-sha2-nistp256 , ssh-rsa , ssh-ed25519 , rsa-sha2-256 and rsa-sha2-512 .
-vserver <Vserver Name> - Vserver
Identifies the Vserver to which you want to add additional SSH key exchange algorithms or ciphers.
[-key-exchange-algorithms <algorithm name>,…​] - List of SSH Key Exchange Algorithms to Add
Adds the specified SSH key exchange algorithm or algorithms to the Vserver.
[-ciphers <cipher name>,…​] - List of SSH Ciphers to Add
Adds the specified cipher or ciphers to the Vserver.
[-mac-algorithms <MAC name>,…​] - List of SSH MAC Algorithms to Add
Adds the specified MAC algorithm or algorithms to the Vserver.
[-host-key-algorithms <HostKey Algorithms>,…​] - List of SSH Host Key Algorithms to Add
Adds the specified host key algorithms to the Vserver.
The following command adds the diffie-hellman-group-exchange-sha256 and diffie-hellman-group-exchange-sha1 key exchange algorithms for the cluster1 Vserver. It also adds the aes256-cbc and aes192-cbc ciphers and the hmac-sha1 and hmac-sha2-256 MAC algorithms to the cluster1 Vserver.
cluster1::> security ssh add -vserver cluster1 -key-exchange-algorithms diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1 -ciphers aes256-cbc,aes192-cbc -mac-algorithms hmac-sha1,hmac-sha2-256 -host-key-algorithms ecdsa-sha2-nistp256,ssh-rsa,rsa-sha2-256,rsa-sha2-512
