Command reference
statistics archive config show
Display Cluster-Wide Performance Archive Configuration
Displays cluster-wide performance archive configuration settings.
Note the following read-only values are displayed for informational purposes and cannot be directly controlled here:
  • "Base Path" (datastore-path ) cannot be modified.
  • "Data ONTAP Version" (version ) cannot be modified.
  • "Enabled Performance Preset Names" (enabled-preset-name ) are managed by the statistics preset modify command.
  • "Hours to Retain Agent Archive Data" (agent-max-retention ) are managed by the statistics archive config modify command.
cluster::*> statistics archive config show
Is the Performance Archive Enabled?: true
      Base Path of Performance Archive Datastore: /mroot/etc/log/stats/ccma
         Days to Retain Performance Archive Data: 28
Maximum Percentage of Root Volume Used for Performance Archive Data: 10%
Minutes Between Performance Archive Data File Rotations: 15
            Minutes Between Perfstat Collections: 5
         Minutes Between OPM Data File Rotations: 5
              Hours to Retain Agent Archive Data: 12
   Data ONTAP Version of Installed Configuration: 8.3.2
                Enabled Performance Preset Names: asup-hourly, default, opm,
                                                  ps, resource_test, statit,
                                                  sysstat_all, sysstat_mp,
                                                  waffinity_stats, wafl_cpm,
                                                  wafl_susp
