Command reference
storage shelf firmware update
Update Shelf Firmware
The storage shelf firmware update command updates the firmware on one or more shelves. You can download the latest firmware by using the storage firmware download command. You can specify a shelf whose firmware is to be updated by using the -shelf parameter. You can update the firmware on all the shelves by not providing the -shelf parameter. All the shelves of a specific module type can be updated by providing a value to the -module-type parameter.
{ [-shelf <text>] - Shelf Name (privilege: advanced)
This specifies the name of the shelf whose firmware is to be updated.
| [-module-type {iom12|iom12e|iom12b|nsm100|nsm8e|iom12g|nsm16e|iom12c|nsm100b|nsm100c}] - Shelf Module Type (privilege: advanced) }
Update the firmware on the shelves that match the module-type you specify.
[-refresh <true>] - Refresh (privilege: advanced)
Forces an update on the shelf with the highest revision of the applicable firmware, resulting in a refresh of the firmware image already present on the shelf.
The following example updates the firmware on all the shelves in the cluster:
cluster1::*> storage shelf firmware update
The following example updates the firmware on all shelves with the IOM12 module type:
cluster1::*> storage shelf firmware update -module-type IOM12
The following example updates the firmware on shelf 1.2:
cluster1::*> storage shelf firmware update -shelf 1.2
The following example refreshes the firmware on all shelves with the IOM12 module type:
cluster1::*> storage shelf firmware update -refresh -module-type IOM12
The following example refreshes the firmware on shelf 1.2:
cluster1::*> storage shelf firmware update -refresh -shelf 1.2
