Command reference
system controller replace resume
Resume paused controller replacement
The system controller replace resume command is used to resume an update that is currently in one of paused-on-request, paused-on-error or paused-for-intervention states. If the update is not paused then an error is returned.
The following example shows a resume operation:
cluster1::> system controller replace resume
Controller replacement resumed successfully.
