Command reference
system node image package external-device show
Display file listing on external device
The external-device show command displays files residing on the external storage device.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-node {<nodename>|local}] - Node (privilege: advanced)
This parameter selects the node that has files that are to be displayed on the external storage device. If this parameter is omitted, then the local node is the default node.
[-package <text>] - File Name (privilege: advanced)
This parameter specifies the file for which the information is displayed.
[-device {usb0|usb1}] - Device (privilege: advanced)
This parameter specifies the name of the external device. Currently, only usb0 is supported.
usb0 refers to the first external USB device connected to the node (regardless of port).
cluster1::> system image package external-device show
Node                     Device          Package File Name
node-01                  usb0            image.tgz
node-01                  usb0            netboot.tgz
2 entries were displayed.
