Command reference
system switch ethernet support show
Display Ethernet switch support status.
The system switch ethernet support show command displays the switch model, firmware or software version, and RCF support information.
{ [-fields <fieldname>,…​]
| [-instance ] }
If this parameter is specified, the command displays information about all entries.
[-device <text>] - Switch Name
If this parameter is specified, the command only displays support details of the provided Ethernet switch.
[-support-status <text>] - Support Status
If this parameter is specified, the command displays only Ethernet switches with the provided support status.
[-recommended-action <text>] - Recommended Action
If this parameter is specified, the command displays only Ethernet switches with the provided recommended action.
cluster1::> system switch ethernet support show
Switch                    Support Status     Recommended Action
            switch-name01(Switch--SN) Ok                 -
            switch-name02(Switch--SN) Unsupported FW     Upgrade RCF: XXX
Displays the Ethernet switches, their support status, and the recommended action to take.
