Command reference
volume clone quiesce-lun show
Show the quiesced state of the LUN
The volume clone quiesce-lun show command reports the quiescence state of the LUN. By default, this command displays the following information:
  • Vserver Name
  • Volume Name
  • LUN Name
  • LUN Quiesced State
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-vserver <Vserver Name>] - Vserver Name (privilege: advanced)
This parameter shows the Vserver name on which the volume resides.
{ [-path <path>] - LUN Path (privilege: advanced)
Specifies the path of the LUN. The LUN path cannot contain any files.
| [-volume <volume name>] - Volume Name (privilege: advanced)
This parameter shows the volume name on which the LUN resides.
[-qtree <qtree name>] - Qtree Name (privilege: advanced)
Specifies the qtree that contains the LUN.
[-lun <text>] - LUN Name (privilege: advanced) }
This parameter shows the LUN name which is being processed for data migration.
[-state <text>] - LUN Quiesced State (privilege: advanced)
This parameter specifies the quiesced state of the LUN.
The following example displays information about the state of the LUN:
cluster1::> volume clone quiesce-lun show
Vserver       LUN Path                      LUN Quiesced State
vs1           /vol/vol1/lun1                Quiesced
The following example displays information about LUN lun1 residing on Vserver vs1 :
cluster1::> volume clone quiesce-lun show -vserver vs1 -path /vol/vol1/lun1 -instance
Vserver Name: vs1
               Volume Name: vol1
                  LUN Path: /vol/vol1/lun1
        LUN Quiesced State: Quiesced
                Qtree Name: ""
                  LUN Name: lun1
