Command reference
volume clone quiesce-lun stop
Unquiesce a LUN to restore I/O operations if a failure occurs during non-disruptive data migration
The volume clone quiesce-lun stop command stops the quiescence process for the specified LUN. Quiesce and unquiesce operations are typically used during data migration to pause and resume I/O activity on the LUN and its associated metadata.
-vserver <Vserver Name> - Vserver Name (privilege: advanced)
This parameter specifies the Vserver that the volume exists on.
{ -path <path> - LUN Path (privilege: advanced)
Specifies the path of the LUN. The LUN path cannot contain any files.
| -volume <volume name> - Volume Name (privilege: advanced)
This parameter specifies the volume that the LUN exists on.
[-qtree <qtree name>] - Qtree Name (privilege: advanced)
Specifies the qtree that contains the LUN.
-lun <text> - LUN Name (privilege: advanced) }
This parameter specifies the LUN name which will be unquiesce during data migration.
The following example starts to unquiesce the LUN lun1 on Vserver vs1 :
cluster1::> volume clone quiesce-lun stop -vserver vs1 -path lun1
