volume flexgroup prepare-to-downgrade
Disables flexgroup version specific features
The volume flexgroup prepare-to-downgrade command prepares the cluster to revert/downgrade by disabling the FlexGroup features that are not compatible with earlier versions of ONTAP. In 9.18.1 and 9.17.1 versions, this command disables the Arbitrary Part Sizes feature if there are no volumes that are using it.
The following example disables FlexGroup features that are not compatible with earlier versions.
cluster::*> flexgroup prepare-to-downgrade
