Command reference
vserver migrate precheck show
Display Vserver migrate precheck results
add text
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <text>] - Vserver
Selects migrate precheck results for Vservers that match the specified value.
[-id <integer>] - Error ID
Selects migrate precheck results with identifiers that match the specified value.
[-start-time <MM/DD/YYYY HH:MM:SS>] - Start Time
Selects migrate precheck results with start times that match the specified value.
[-end-time <MM/DD/YYYY HH:MM:SS>] - End Time
Selects migrate precheck results with end times that match the specified value.
[-result <text>] - Overall Result
Selects migrate precheck results with an overall result that matches the specified value.
[-target-personality {unknown|unified|asa|asar2|afx}] - Target Personality
Selects migrate precheck results with target personalities that match the specified value.
[-error <text>] - Error
Selects migrate precheck results with errors that match the specified value.
add text
