ONTAP EMS reference
cam.dev events
cam.dev.fuaNotSupported
Severity
ALERT
This message occurs when the disk does not support the Forced Unit Access (FUA) feature bit. Using this disk with the write cache enabled can lead to data corruption.
Corrective Action
Use disks with the write cache disabled or disks where the FUA feature is supported.
Syslog Message
FUA feature is not supported for disk %s%d with target address %s.
periph_name (STRING): Disk name.
unit (INT): Unit number.
target_addr (STRING): Disk target address.
cam.dev.fuaNotVerified
Severity
ALERT
This message occurs when ONTAP® software fails to read the SCSI page containing the Forced Unit Access (FUA) feature bit. Using the disk with the write cache enabled and FUA not supported can lead to data corruption.
Corrective Action
Because ONTAP cannot determine the state of the FUA feature bit, disable the disk write cache if it is enabled by default. If the write cache cannot be disabled, replace the disk to avoid corruption.
Syslog Message
Unable to read the FUA settings for disk %s%d with target address %s.
