ONTAP EMS reference
cpeer.access events
cpeer.access EMS events occur when an access request from a peer cluster is rejected, either because the request is made to a restricted Vserver or to a restricted table.
cpeer.access.restricted
Severity
ERROR
This message occurs when an access request from a peer cluster is rejected, either because the request is made to a restricted Vserver or to a restricted table.
Corrective Action
Check the Vserver peering relationships with the peer cluster. If additional Vserver access is required, use the "vserver peer create" command to initiate the peering relationship with the peer cluster.
Syslog Message
An access request from peer cluster %s (IP: %s) was denied. Reason: %s.
peer (STRING): Name of the peer cluster making the request to the local cluster.
address (STRING): Source IP address of the incoming request.
reason (STRING): Reason for the access restriction.
