dfu.fwdownloadfailedmultfiles events
Creating your file...
Your file is ready
dfu.fwDownloadFailedMultFiles
- Severity
ERROR
- Description
This message occurs when more than one file is found for downloading to an ATA drive. Because there is no version string control, only one file at a time is allowed on the system.
- Corrective Action
Two or more firmware files were found for download. Delete all except the one that should be downloaded to the drive. Background firmware update should download on the next check cycle.
- Syslog Message
Download failed due to multiple firmware files found for Disk type [%s %s].
- Parameters
vendorName (STRING): Vendor name of the disk.
productId (STRING): Product ID of the disk.
