The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
fcvi.unsupported events
Creating your file...
Your file is ready
fcvi.unsupported.config
- Severity
ERROR
- Description
This message occurs when a network adapter port behavior type is set to use FC-VI on a platform that has not been validated for its use and is therefore unsupported.
- Corrective Action
Change the port behavior type to a value other than "FC-VI". Use the "system hardware unified-connect show" command to view network adaptor port information, including the current behavior type. Use the "system hardware unified-connect modify" command to change the network adapter port behavior type.
- Syslog Message
FC-VI port behavior type not supported on network adapter port %s.
- Parameters
port (STRING): The network adapter port whose behavior type is set to use FC-VI.
