The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
fg.admin events
Creating your file...
Your file is ready
fg.admin.wait.long
- Severity
NOTICE
- Description
This message occurs when the data component takes longer than 15 seconds to update its view of the FlexGroup volume after an admin operation.
- Corrective Action
(None).
- Syslog Message
FlexGroup volume "%s" (MSID "%lu") in Vserver "%s" took %lu seconds to update the "%s" property during the "%s" operation.
- Parameters
volumeName (STRING): Name of the FlexGroup volume.
volumeMsid (LONGINT): Master Data Set ID (MSID) of the FlexGroup volume.
vserverName (STRING): Name of the Vserver on which the FlexGroup volume resides.
numSeconds (LONGINT): Number of seconds that the data component took to update.
property (STRING): Volume property being updated.
operation (STRING): Admin operation performed before the data component update.
