The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
geom.ontap events
Creating your file...
Your file is ready
geom.ontap.orphan.removing
- Severity
NOTICE
- Description
This message occurs when the geometry layer (geom) detects a device to be detached from the system.
- Corrective Action
(None).
- Syslog Message
Removing unit %d type %d.
- Parameters
unit (INT): Unit number.
disk_type (INT): Disk type.
