license.feat events
Creating your file...
license.feat.delete.failed
- Severity
ERROR
- Description
This message occurs when the system cannot successfully delete a license for a feature. (This message is currently used only for FlexCache® licenses.)
- Corrective Action
The feature might be vetoing deletion for specific, valid reasons (e.g., it is still in use), or it might be in a state that is inconsistent with deletion. Examine the error condition for more information. Contact NetApp technical support.
- Syslog Message
License for feature %s and serial %s not deleted: %s.
- Parameters
feature (STRING): Name of the feature.
serial (STRING): Serial number associated with the license.
reason (STRING): Error condition encountered.
license.feat.deleted
- Severity
NOTICE
- Description
This message occurs when the system deletes a license for a feature. (This message is currently used only for FlexCache® licenses.)
- Corrective Action
(None).
- Syslog Message
License deleted: feature %s, serial %s.
- Parameters
license.feat.install.failed
- Severity
ERROR
- Description
This message occurs when the system cannot successfully install a license for a feature. (This message is currently used only for FlexCache® licenses.)
- Corrective Action
Check whether the feature is supported by the target instance of ONTAP® software. Check whether the target instance supports the change in the entitlements as specified by the license. Contact NetApp technical support.
- Syslog Message
License for feature %s and serial %s not installed: %s.
- Parameters
license.feat.installed
- Severity
NOTICE
- Description
This message occurs when the system successfully installs a license for a feature. (This message is currently used only for FlexCache® licenses.)
- Corrective Action
(None).
- Syslog Message
License installed for feature %s: serial: %s, %s.
- Parameters
attrs (STRING): Attributes of interest for this license, listed as a colon-separated key-value pairs.
