ONTAP EMS reference
mgmtgwd.snapshot events
mgmtgwd.snapshot EMS events occur when ONTAP encounters issues associated with snapshot operations on Infinite Volumes.
mgmtgwd.snapshot.deleteWarn
Deprecated
Deprecated as of Data ONTAP 9.6 because Infinite Volumes no longer exist.
Severity
NOTICE
This message occurs when a Snapshot(tm) copy cannot be deleted from an Infinite Volume.
Corrective Action
Delete one or more older Snapshot copies associated with this schedule by using the "volume snapshot delete" command.
Syslog Message
Skipping deletion of scheduled Snapshot copy "%s" on volume "%s" on Vserver "%s" for schedule "%s" prefix "%s" (reason: %s).
snapshotName (STRING): Name of the Snapshot copy.
volumeName (STRING): Name of the volume.
vserverName (STRING): Name of the Vserver.
scheduleName (STRING): Name of the Snapshot policy schedule.
prefixName (STRING): Name of the prefix associated with the Snapshot policy schedule.
reason (STRING): Reason for the failure.
mgmtgwd.snapshot.frcRestore
Deprecated
Severity
INFORMATIONAL
This message occurs when a Snapshot(tm) copy is restored on an Infinite Volume using the 'force' option.
Corrective Action
(None).
Syslog Message
Volume '%s' on Vserver '%s' was restored to Snapshot copy '%s' using the 'force' option.
mgmtgwd.snapshot.partCreate
Deprecated
Severity
ERROR
This message occurs when a Snapshot(tm) copy is partially created on an Infinite Volume. Residual Snapshot copies might remain on one or more Infinite Volume constituent volumes. These Snapshot copies might consume the Snapshot reserve on the constituent volumes.
Corrective Action
Contact NetApp technical support.
Syslog Message
Scheduled Snapshot copy '%s' of volume '%s' on Vserver '%s' for schedule '%s' prefix '%s' was partially created and cleanup failed on one or more constituent volumes.
constituentMsidList (STRING): List of master data set IDs (MSIDs) of Infinite Volume constituent volumes that might have residual Snapshot copies.
mgmtgwd.snapshot.tooManySnap
Deprecated
Severity
ERROR
This message occurs when a Snapshot(tm) copy cannot be created on an Infinite Volume because too many Snapshot copies exist for the associated schedule.
Corrective Action
Delete an older Snapshot copy associated with this schedule using the 'volume snapshot delete' command.
Syslog Message
Scheduled Snapshot copy '%s' of volume '%s' on Vserver '%s' could not be created because too many Snapshot copies exist for the associated schedule.
