moveagent.commitsrc events
Creating your file...
Your file is ready
moveagent.commitsrc.fail
- Severity
ALERT
- Description
This message occurs when an active volume move operation cannot commit the source volume. The system continues to retry the operation until it is successful. In the time between the failure and a successful retry, there might be disruption to client traffic associated with the volume being moved.
- Corrective Action
Monitor the volume move job. If the problem persists, contact NetApp technical support
- Syslog Message
Unable to finish the volume move operation for DSID %llu. Failed to commit the source volume.
- Parameters
volume_dsid (LONGINT): Source volume Data Set ID (DSID).
