The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nand.unable events
Creating your file...
Your file is ready
nand.unable.to.monitor
- Severity
ALERT
- Description
This message occurs when Data ONTAP® module that is responsible for monitoring the health of the NVRAM device cannot extract health information. This failure might indicate the NVRAM device is not operating properly.
- Corrective Action
Use the "system environment sensors show" command to verify the device's status. If the failure still exists, contact technical support for assistance.
- Syslog Message
Unable to monitor NVRAM device: %s.
- Parameters
device (STRING): Name of the device.
