The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
nblade.showmountdisabled events
Creating your file...
Your file is ready
- Severity
ERROR
- Description
This message occurs when the "showmount" command is triggered by client, but the command is disabled on the NFS server. The "showmount" command enables NFS clients to see the Vserver's NFS exports list.
- Corrective Action
Use the "nfs modify -showmount enabled" command to enable the feature. Use the "nfs show -fields showmount" command to verify that, if the showmount feature was enabled successfully on the NFS server.
- Syslog Message
Showmount is disabled on Vserver %d.
- Parameters
vserverid (INT): Identifier for the Vserver associated with this operation.
