ONTAP EMS reference
net.vserverupdatesuccess events
net.vserverupdatesuccess EMS events occur when the Vserver configuration on a node is successfully updated after a previous failure.
net.vServerUpdateSuccess
Severity
NOTICE
This message occurs when the Vserver configuration on a node is successfully updated after a previous failure.
Corrective Action
(None).
Syslog Message
Vserver configuration is successfully updated on node %s.
remote_node (STRING): Node that was updated.
