ONTAP EMS reference
nvpm.extend events
nvpm.extend EMS events occur when nvlog client segments cannot be enabled in a partner NVRAM section following a controller failover or MetroCluster® switchover.
nvpm.extend.failed
Severity
ERROR
This message occurs when nvlog client segments cannot be enabled in a partner NVRAM section following a controller failover or MetroCluster® switchover. When this event occurs, the system continues to operate, but with diminished performance due to the increased failover load coupled with decreased NVRAM capacity for logging.
Corrective Action
Perform a storage system giveback operation or a metrocluster switchback operation to restore operating performance.
Syslog Message
Client segments cannot be enabled due to a %s.
event (STRING): Event that triggered the extension.
current_state (INT): (debug only) Current Non-volatile RAM Partition Manager (NVPM) state.
expected_state (INT): (debug only) Expected NVPM state.
reason (INT): (debug only) Reason for the extension failure.
