ONTAP EMS reference
qos.mintp events
qos.mintp.high.intrconct.lat
Severity
NOTICE
This message occurs when the Quality of Service (QoS) subsystem notices high latency in the cluster interconnect for workloads associated with minimum-throughput policy groups. As a result, workloads might not be able to meet their minimum-throughput values.
Corrective Action
Consider using the "qos statistics" CLI command to monitor the workloads and policy groups that have high cluster interconnect latency and also do not meet their minimum-throughput Service Level Objectives (SLOs). Either avoid the interconnect by moving workloads or LIFs, or reduce contention for the interconnect by applying QoS maximum throughput constraints on interfering workloads.
Syslog Message
QoS has noticed high cluster interconnect latency. Some workloads and policy groups might not meet their specified minimum-throughput.
(None).
