ONTAP EMS reference
rpl.src events
rpl.src EMS events occur when the replication source finds a LUN clone in a snapshot that was created on a ONTAP version earlier than 7.3 and was attempting to transfer as a LUN clone instead of a LUN.
rpl.src.lun.old_clone
Severity
ERROR
This message occurs when the replication source finds a LUN clone in a Snapshot(tm) copy that was created on a Data ONTAP® version earlier than 7.3 and was attempting to transfer as a LUN clone instead of a LUN. Transferring a LUN clone in a Snapshot(tm) copy that was created on Data ONTAP version earlier than 7.3 as a LUN clone might lead to divergence on the replication destination.
Corrective Action
Only SnapVault® transfers that are managed using Ontapi can get into this situation. If SnapVault® restore is using a named Snapshot copy transfer, then choose a different named Snapshot copy. If SnapVault® is not using named Snapshot copy transfer, then delete the Snapshot copy and try again.
Syslog Message
%s transfer from %s:%s to %s:%s is attempting to transfer a LUN clone from a pre Data ONTAP 7.3 Snapshot copy %s to the destination as a LUN clone.
transfer_type (STRING): Type of the transfer.
source_filer (STRING): System name of the replication source.
source_path (STRING): Path of the qtree where the clones reside.
dest_filer (STRING): System name of the replication destination.
dest_path (STRING): Replication destination path.
snapname (STRING): Name of the backup Snapshot copy of the LUN clone.
