secd.cifsauth events
Creating your file...
secd.cifsAuth.denied
- Severity
ERROR
- Description
This message occurs when a CIFS authentication attempt fails for any reason other than an unknown user name or bad password.
- Corrective Action
Examine the failure details to determine corrective action. A common failure is the inability to communicate with a domain controller.
- Syslog Message
vserver (%s) Cannot authenticate CIFS user. %s
- Parameters
vserverName (STRING): vserver associated with this operation.
failureDetail (STRING): Error journal is a collection of events leading up to a failure. This failure is likely to impact many (if not all) users, and might reflect a misconfiguration or environmental problem..
secd.cifsAuth.noNameMap
- Severity
ERROR
- Description
This message occurs when a CIFS authentication succeeds, but system cannot map the Windows user to an appropriate UNIX user.
- Corrective Action
Examine the failure details to determine corrective action. Common failures include no appropriate Windows-to-UNIX name mapping rules, no configured default UNIX user, or the inability of the system to communicate with NS-SWITCH authorization sources.
- Syslog Message
vserver (%s) CIFS name to UNIX name mapping problem. %s
- Parameters
secd.cifsAuth.noUnixCreds
- Severity
ERROR
- Description
This message occurs when the system is unable to retrieve necessary UNIX credentials for a Windows user during the CIFS authentication process.
- Corrective Action
Examine the failure details to determine corrective action. A common failure is the inability to communicate with NS-SWITCH authorization sources.
- Syslog Message
vserver (%s) Cannot get UNIX credentials for CIFS user. %s
- Parameters
secd.cifsAuth.problem
- Severity
ERROR
- Description
- Corrective Action
Examine the failure details to determine corrective action. Common failures include the inability to communicate with domain controllers, NIS servers, or LDAP servers due to connectivity or configuration problems.
- Syslog Message
vserver (%s) General CIFS authentication problem. %s
- Parameters
