ses.multipath events
ses.multipath.notSupported
- Severity
NOTICE
 - Description
This message occurs when the AT-FCX disk shelf module does not support the multipath high-availability (Multipath HA) configuration.
 - Corrective Action
Replace this disk shelf module with one that supports the high-availability multipath configuration.
 - Syslog Message
AT-FCX disk shelf module %s on disk shelf %d on channel %s does not support the-high availability multipath configuration. Replace the module with one that supports the-high availability multipath configuration.
 - Parameters
shelfSlot (STRING): Slot position the disk shelf module is in, either A for the top slot or B for the bottom slot.
shelfId (INT): Disk shelf identification number of the disk shelf.
channelName (STRING): Name of the channel of the disk shelf.
ses.multipath.ReqError
- Severity
ALERT
 - Description
This message occurs when the system detects that a SAS disk shelf is in a single-path cabling configuration.
 - Corrective Action
Check for SAS disk shelf enclosures with only a single path by using the 'sasadmin expander_map' command. Physically inspect all SAS cables on the attached storage for secure and correct connection.
 - Syslog Message
SAS disk shelf detected without a multipath configuration.
 - Parameters
(None).
