      sis.corrupt events
sis.corrupt.metafile.deleted
- Severity
NOTICE
 - Description
This message occurs when a Single Instance Storage (SIS) metafile is deleted because there are Disk/Media errors affecting the file.
 - Corrective Action
The deleted metafile might be recovered automatically the next time you run the 'sis start' command. If you have not previously run the 'sis start' command on this volume, run the 'sis start -s' command to generate metafiles and obtain efficient deduplication. Contact NetApp technical support for guidance.
 - Syslog Message
SIS metafile on volume '%s%s' is deleted.
 - Parameters
volume (STRING): Volume path.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
