ONTAP EMS reference
slice.service events
slice.service EMS events occur when the cluster attempts to migrate data away from an unresponsive Slice Service.
slice.service.unhealthy
Severity
ALERT
This message occurs when the cluster is trying to migrate data away from an unresponsive Slice Service.
Corrective Action
Expect cluster to automatically resolve this failure. The system is automatically decommissioning data and re-replicating its data onto other healthy drives.
Syslog Message
The cluster is attempting to migrate data away from unresponsive Slice Service ID %u on node %u.
serviceID (INT): Service ID. Identifies the associated cluster service.
nodeID (INT): Node ID. Number of the associated node.
cfType (STRING): Cluster fault type name. Describes the type of the associated object.
cfID (INT): Cluster fault ID. A unique, monotonically increasing number associated with the fault.
cfStatus (INT): Cluster fault current status. 1=New (just reported), 2=Existing (updated), 3=Resolved (closed).
cfDetails (STRING): Cluster Fault Details. This is a text description of the cluster fault including context details.
cfExtSrc (STRING): Cluster Fault externalSource. This is a label attached to a fault created by the CreateClusterFault API command, used for testing.
