ONTAP EMS reference
sm.disable events
sm.disable EMS events occur when ONTAP encounters issues associated with storage efficiency disablement during SnapMirror® operations.
sm.disable.se
Severity
NOTICE
This message occurs when the "storage efficiency" feature on a destination volume is automatically disabled successfully by the SnapMirror® resync or update operation.
Corrective Action
(None).
Syslog Message
Disabled the "storage efficiency" feature for volume %s during a %s.
dst_path (STRING): Destination FlexVol® volume path on which the "storage efficiency" feature is disabled.
workflow_type (STRING): Workflow that disabled the "storage efficiency feature".
sm.disable.se.fail
Severity
ERROR
This message occurs when the "storage efficiency" feature fails to be disabled on a destination volume during a SnapMirror® resync or update operation.
Corrective Action
Disable storage efficiency manually by using the "volume efficiency off "volume_name" " command. If the failure persists, contact NetApp technical support.
Syslog Message
Failed to disable the "storage efficiency" feature for volume %s during a %s. Reason: %s.
dst_path (STRING): Destination FlexVol® volume path on which the "storage efficiency" feature failed to be disabled.
workflow_type (STRING): Workflow that failed to disable the "storage efficiency" feature.
reason (STRING): Reason for the failure.
