sp.dhcp events
Creating your file...
Your file is ready
sp.dhcp.failure
- Severity
ERROR
- Description
This message occurs when the Service Processor (SP) cannot obtain network configuration data through DHCP. The SP cannot be reached from the network.
- Corrective Action
Verify that DHCP services are available, or configure the SP with a static address. If failures persist, contact NetApp technical support.
- Syslog Message
Service Processor cannot obtain network configuration using DHCP.
- Parameters
(None).
