The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
spm.upgrademgr events
Creating your file...
Your file is ready
spm.upgrademgr.process.exit
- Severity
ERROR
- Description
This message occurs when the upgrade manager server (upgrademgr) involuntarily terminates.
- Corrective Action
The system attempts to recover by restarting the upgrademgr process server. If the process does not restart within the threshold number of retries, then an AutoSupport® message is sent. If your system is not configured to send AutoSupport messages and the issue persists, contact NetApp technical support.
- Syslog Message
The upgrade manager server (upgrademgr) with ID %d exited as a result of %s. This server will attempt to restart.
- Parameters
id (INT): Process identifier.
cause (STRING): Plain text description of why the process exited.
